Turn Popping/binding in 2wd
Old Jan 14, 2013 | 07:38 AM
  #31
coolasice's Avatar
coolasice will become famous soon enough
Originally Posted by coolasice
My original plan was to try to turn each equal amounts to try to center my steering wheel, then adjust each a slight amount out, then have a alignment check done (free at the local sears).
well that didn't work out..... could not get the sleeve to turn, guess I'll just have to wait til spring and order new parts
Old Oct 18, 2013 | 09:04 AM
  #32
coolasice's Avatar
OK... bringing back the dead, that pop/binding is back. it seems to be coming from the left side, I can feel it bind up once every tire revolution, then pop. not sure where to go from here.... things I've done since... all control arm bushings, all new tie rods, idler, pitman, lubed stops, complete alignment, changed CV shafts.... what the heck could it be? only happens at full right lock going forward. happens regardless of 2wd or 4wd
Old Oct 18, 2013 | 02:25 PM
  #33
Just for grins & giggles, try disconnecting the vacuum line from the axle actuator under the battery, then drive it. If the noise goes away, the O rings inside the transfer case vacuum switch are leaking.
Old Oct 18, 2013 | 05:14 PM
  #34
coolasice's Avatar
vacuum switch was replaced this spring with a new acdelco one...
Old Oct 18, 2013 | 05:20 PM
  #35
Just trying to come up with possibilities based on your symptoms. Just cuz it's new, doesn't mean it's good
Old Oct 18, 2013 | 05:28 PM
  #36
coolasice's Avatar
its def not engaging the axle, I've checked that already. I'm wondering if the bearing on the diff where the axle slides in could be going out? wish I had a gopro with a mag mount...would make seeing what's going on much easier...
Old Oct 20, 2013 | 01:35 PM
  #37
Fred Nutcase's Avatar
Fred Nutcase is on a distinguished road
Sounds like a good reason to buy a really cool "tool" to me.........
Old Oct 20, 2013 | 06:00 PM
  #38
What about a binding caliper guide pin? Wouldn't take much lateral rotor runout to make it bind up.
Old Oct 20, 2013 | 06:38 PM
  #39
coolasice's Avatar
nope, just did brakes, was binding before that...
Old Oct 20, 2013 | 06:39 PM
  #40
coolasice's Avatar
its weird, only does it in forward and full right lock, not in reverse
