Turn Signal Flasher Location????
Old Feb 22, 2010 | 10:38 AM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
Default Turn Signal Flasher Location????
98 Blazer Zr2. Need help finding turn signal flasher relay. All i can find out is that is behind the right side of the dash. does anyone have pics of the location or know what has to come out to replace it like the glovebox or kickpanel??? Thanks in advance!!!
Old Feb 22, 2010 | 10:56 AM
It should be located behind the glove box. This should help:
To fully open the glove box, first empty out the contents of the glove box if you do not want it all to end up on the floor. Then locate the retaining tab in the upper left corner of the glove box opening in the dash. Lift up on the spring loaded retaining tab and rotate the glove box out.
Check out THIS POST for pictures. It is unrelated, but does show the flasher relay which is the part that is held in by the green strap.
Old Feb 22, 2010 | 11:17 AM
just what i needed!
Old May 31, 2012 | 02:57 PM
sk8erbro76's Avatar
sk8erbro76 is on a distinguished road
How did you tale off the green strap?
Old Nov 27, 2012 | 06:27 PM
Chevyrider RevT's Avatar
Chevyrider RevT is on a distinguished road
its just as bit confusing on the diagram (utility) is for blazer right?
and if so which is the driver side flasher 2?4?3? or 6?
Old Nov 27, 2012 | 08:06 PM
spittybays
Guest
Posts: n/a
My signal flashers are behind the dash upper left of the ashtry under the radio. If I remember you take the bottom panel under the steering column off. Not sure if that's the correct diagram. Check the google searh box on the BF home page. I sure could be wrong.
Old Nov 27, 2012 | 08:18 PM
4x4blazerguy's Avatar
One flasher is for your 4way flashers the other is your turn signals both sides.
Old Nov 28, 2012 | 05:04 AM
which is which? and can i still splice into the directionals or is it going to be connected to both sides ??
Old Jul 20, 2025 | 04:32 PM
minnie1001's Avatar
minnie1001 is on a distinguished road
The green strap is a wire tie Cut it.
tomthowell
Aug 26, 2015 03:28 PM
TAZ454
Oct 18, 2012 07:05 AM
piscespokerbrat
May 25, 2012 01:00 AM
dundeeboy
Nov 9, 2010 05:54 PM
guyd_15
Jul 3, 2009 04:21 PM
