hazard he##
Old Aug 19, 2015 | 06:34 PM
tomthowell's Avatar
tomthowell is on a distinguished road
Default hazard he##
I have a 1998 blazer and my hazard will not flash but a couple of times then stay on all t he time what do I need to do???
Old Aug 19, 2015 | 06:48 PM
tenorsaxdude's Avatar
tenorsaxdude is on a distinguished road
Sounds like a bad flasher unit. I'm safe to assume the clicking sound stops as well?
If so I would target the flasher unit which I believe in the 98's is located behind the glove box.
Remove the contents of your glove box before pressing on the retention pin in the left top corner to allow the box to swing down into the footwell allowing for access behind it. Flasher unit will be a small little relay box on the right side with a white or green retention strap around the outside of it.
Old Aug 19, 2015 | 06:53 PM
tomthowell's Avatar
Default ok
I can't remove the glove box because the vehicle is modified to drive on the right hand side is there another way to get to it??
Old Aug 19, 2015 | 07:02 PM
I would have to see pictures on this to be sure.
I assume by modified, it was originally a left hand drive?
Old Aug 19, 2015 | 07:05 PM
tomthowell's Avatar
Yes it was a left hand drive originally. Wife needed a postal vehicle so it is a r/s drive now. I will send pics tommorrow..
Old Aug 19, 2015 | 10:45 PM
richphotos's Avatar
Since it was modified to be a RHD.. When the flasher is working, are you able to hear the clicking? If so, locate that clicking sound to find the flasher...
Old Aug 26, 2015 | 03:28 PM
Thogert's Avatar
The hazard switch has been known to cause weirdness as well. Something to check if you can't find the flasher, or the flasher is fine.
blazin97
Oct 27, 2009 09:04 AM
TonyOneX
Apr 14, 2007 12:34 AM
RdizzLe
Jul 11, 2006 05:48 PM
RdizzLe
Detailing
Jul 10, 2006 03:41 PM
rryker
Apr 25, 2006 04:14 PM
