Turn signal noise...to begin with
Old Mar 30, 2007 | 02:54 AM
roentgeno's Avatar
roentgeno is an unknown quantity at this point
Default Turn signal noise...to begin with
Ok, a month ago I got in a wreck and crushed (not enough to disable the car) the front passenger corner of my 1999 Chevy Blazer. Immediately after that I noticed the turn signal noise going off constantly with or without the turn signals on.Everything else was working fine until recently.Two weeks after the wreck, I had to change my battery. Thats not really a big deal, but the fact that it happened after my wreck concerned me.
Last week, some newer issues popped up. Not only am I still hearing the ticking noise, last weekend when my turn signal was actually turned on there was a brief moment it stuck on with a horrible noise almost like an elictrical zap. It then began working normal almost immediately. I have also noticed my temperature gauge, no matter how long I have driven, reads lower than normal and the oil psi read low when I am stopped. The oil thing may be normal, but I can't remember if I have evenr seen that. Any information would be great guys and gals. Thanks for reading this!
Old Mar 31, 2007 | 12:25 AM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: Turn signal noise...to begin with
The turn signal switch should cure your noise there. It is possible that the t-stat is sticking open and causing the low temp reading, and now that it is starting to get warmer out, your oil pressure could go lower at operating temp at an idle, that is normal.
Old Mar 31, 2007 | 01:10 AM
Zygoat's Avatar
Zygoat is an unknown quantity at this point
my oil press is alwys lower when i am ideling
93S10TahoeLT
62
Nov 16, 2015 08:13 AM
rickmfromnh
Aug 15, 2011 08:37 AM
BlazerBull
Aug 26, 2007 09:26 PM
Devin
Apr 19, 2007 08:12 PM
shaka1111
Feb 13, 2006 02:23 PM
