Underhood Fuse Box
Old May 25, 2010 | 01:08 PM
mh99506's Avatar
mh99506 is on a distinguished road
Default Underhood Fuse Box
Alright, I have done search after search and I am at my wits end. I cannot find the fuse box under the hood. It is supposed to be on the drivers side, on the side of the wheel well, near the junction box. I found the junction box, has a nice little plastic cover on it and about six wires held down with nuts. But no fuse box to be found. I am very frustrated with it, as I have a reoccuring p0141 and need to start troubleshooting the wiring. Any help, or pictures would be greatly appreciated. Am I crazy to think my particular blazer would just have the fuses on the side of the dash?
Old May 25, 2010 | 02:11 PM
DaveHearne's Avatar
DaveHearne is on a distinguished road
It should be just in front of the ABS control unit on the drivers side, about 9" x 6" in size with a single hand bolt holding the top on. It is the S10 Blazer you have I presume?
Check out my profile then look at my album. Check out underhood picture number 2. You will see the fusebox behind my battery. Mine is right hand drive but your fusebox will look the same but be on the opposite side. Your battery should still be on the same side as mine though.
Last edited by swartlkk; May 25, 2010 at 07:17 PM. Reason: **Combining Consective Posts** - Please use the EDIT feature to add information to your post if another member has yet to reply.
Old May 25, 2010 | 07:17 PM
The under hood fuse box came into existence around the 98 model year. 96's will not have it.
Old May 26, 2010 | 10:25 AM
mh86334's Avatar
mh86334 is on a distinguished road
Thank you for the responses, I knew I couldn't be missing something as obvious as a fuse box! I certainly appreciate the help.
Old Mar 7, 2022 | 12:45 AM
BLAZED$H#TBOXCHEV96's Avatar
BLAZED$H#TBOXCHEV96 is on a distinguished road
This please can you tell me where I can locate the other fuses
step66
May 6, 2013 12:25 PM
lombard
Dec 27, 2011 03:54 PM
2001Jimmypwner
Feb 2, 2010 01:54 PM
DetroitMuscle
Jan 19, 2008 10:03 AM
gocartone
Nov 13, 2007 05:35 PM
