Uniqe fuel delivery issue
Old May 12, 2013 | 05:30 PM
FartPump's Avatar
FartPump is on a distinguished road
O.k. So i finally have time to work on the truck again.
Read out the wires at the relay contacts.
Orange wire has 0 volts and good continuity to the vcm connector.
Green and White has zero volts and good continuity to the vcm connector.
Gray wire runs the pump when jumped straight to the battery.
Good grounds.
Swapped in another vcm, no luck. Any ideas before i rip the dash out?
Old May 12, 2013 | 09:14 PM
Orange wire must show battery voltage at all times. This is where the relay gets power to activate the fuel pump. It does NOT go to the PCM, it goes from #9 20 amp fuse to the fuel pump relay. This most likely is why the pump will not run.
Put the original PCM back in the vehicle. No idea where you got it, but I'll bet it was not fully programmed after it was installed.
Old May 30, 2013 | 06:19 PM
FartPump's Avatar
Originally Posted by AndrewO1991
ignition switch?
Bingo!! Ignition switch. Thanks everyone for the help.
nockmypen
Jul 28, 2014 09:30 PM
mwbrown4
19
Jun 16, 2014 04:18 PM
duffnuts23
Feb 27, 2014 10:58 AM
Antne
Mar 16, 2013 06:42 PM
karmafuzion
Apr 9, 2011 12:07 AM
