unsolvable issue
Old Sep 22, 2013 | 10:09 PM
Bildo V.'s Avatar
Bildo V. is on a distinguished road
Default unsolvable issue
hi again
I have a 2001 blazer lt 4wd 4.3 auto
ok so here's the scoop: I changed the radiator about 2 or 3 months ago now as the plastic tank on the drivers side had ruptured and spewed antifreeze everywhere. anywho prior to this I had noticed that the speedo would bounce around I ignored it for a while as I had switched my primary vehicle well I had thot it was the vss I swapped it no change but the primary reason I am posting this is the blazer will start and run in idle position all day when I try to "drive" as it is difficult with no speedo it will run a short distance then stall when in gear at random intervals im thinking elec. issue but im not sure btw it has a new Delphi fuel pump a new filter that was rigged in no leaks anywhere that I noticed. Spark is good as it bit me when I tested the coil lol.
what id like to know is what caused the speedo drop out and is it causing the blazer to stall out
Old Sep 23, 2013 | 01:32 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
My first suspicion would be the vehicle speed sensor. Do some research about the VSS here on the Forum and see if anything matches your situation.
Old Sep 23, 2013 | 03:02 AM
Dobe Rottie Gang's Avatar
Dobe Rottie Gang is on a distinguished road
I agree it does sound very much like the speed sensor is playing up.
Old Nov 21, 2013 | 05:42 AM
Bildo V.'s Avatar
thanks for the help guys i did find part of the problem it was stalling due to the o2 sensor reading had dropped out so the pcm couldn't enter closed loop mode when the block warmed up.
I solved that isuue by replacing the 20 amp fuse labeled oxysen
i have not been able to test the speedo issue as the blazer is currently stuck in my backyard
99bblazer99
Jun 15, 2013 08:38 PM
Little Roober
Dec 17, 2012 03:34 AM
drewb
Jun 2, 2012 10:05 PM
J.R. Clay
Mar 16, 2011 12:33 AM
extreme
Jan 5, 2010 07:29 AM
