Vac leak 99 Blazer 4.3L
Old Oct 3, 2011 | 02:58 PM
ExpressEN1's Avatar
ExpressEN1 is on a distinguished road
Default Vac leak 99 Blazer 4.3L
I took the Blazer to the shop today. Mechanic said the vacuum leak is from the seal where the spider goes thru the upper intake (plenum). He told me needs to remove the upper intake and replace the entire gasket set. Does this sound right?
Old Oct 3, 2011 | 03:36 PM
DaddysBlazer's Avatar
DaddysBlazer is an unknown quantity at this point
There is only one Oring around where the spider goes threw the plenum ,and only one gasket between the plenum and the intake manifold. But yes this can cause a major vacuum leak and cause all kinds of problems
Old Oct 12, 2011 | 04:44 PM
Sirloin's Avatar
Sirloin is on a distinguished road
Default Upper Plenum gaskets
I have a 1996 2 dr BLazer, and this past weekend I pulled the plastic plenum off to look at my fuel injection spider, Fuel pressure regulator and what ever else is in there. I was smelling raw gas occassionally. All of the parts in the fuel system looked ok, but I noticed the bolts that are located closest to the distributor, were loose. Evidence of a vacuum leak showed where the gasket had lifted from the aluminum lower manifold. I went to Oreilly and bought the FelPro silicone set of three gaskets for 20 dollars.
There is a large continuous gasket for the bottom of the plastic upper plenum, one that is an obrounded shape to seal the fuel injection spider opening, and one for the seal between the throttle body and the plastic plenum.
I think alldata says it takes about 3 hours, and is a relatively easy job.
Old Oct 12, 2011 | 05:02 PM
Yes their is an gasket on the bottem of the plenum also, but on the newer models it is just on continous gasket. And yes I stand corrected their is actully three because their is a small 90 on the back right on top of the plenum and that little oring/gasket is hard to find.
blue99blazer
Nov 26, 2014 05:16 PM
djkrash
Jan 8, 2008 03:23 PM
ceanern
Nov 2, 2006 08:19 AM
BUDWZR8
Dec 23, 2005 12:50 AM
MudHawg
Dec 20, 2005 12:56 PM
