vaccum hose ?
Old Apr 16, 2010 | 02:16 PM
JAH0983's Avatar
JAH0983 is on a distinguished road
Default vaccum hose ?
On my 99' blazer theres a spot where it looks like 2 vaccumm hoses need connected. I'm not sure what they go to, but the one has suction and the other does not. I have these pictures if it helps or if not I can take more. The connection? is in the drivers side engine compartment just in front of the firewall fire wall. Any help as to what these are for and if I should connect them would be much obliged.
Attached Thumbnails vaccum hose ?-img00168-20100416-1507.jpg   vaccum hose ?-img00169-20100416-1507.jpg
Old Apr 16, 2010 | 02:20 PM
That yellowed plastic T should connect into the other line that you have tape over. The other end of the T should go into the vacuum reservoir that is located in the driver side fender in that general area. I would replace those cracked vacuum lines first though.
Old Apr 16, 2010 | 02:27 PM
JAH0983's Avatar
10-4 I appreciate your quick response. Thank you I intend on replacing the hoses. Could you tell me what this connection is for. I believe to be for the 4 wheel drive but i'm not 100% sure
Old Apr 16, 2010 | 02:30 PM
Your front axle engagement and most of the doors/etc in the HVAC system is powered by vacuum actuators.
Old Apr 16, 2010 | 02:34 PM
JAH0983's Avatar
Your the man, thanks a million
Asvie
Nov 6, 2010 04:57 PM
bobbie p
May 2, 2010 07:37 PM
gscrippler
Jul 28, 2008 04:00 PM
rob1621
Apr 3, 2008 08:55 PM
bigt
Feb 14, 2007 07:45 PM
