Vacum Resevoir ball
Old Apr 12, 2016 | 05:53 PM
akaSPITTYBAYS's Avatar
akaSPITTYBAYS is on a distinguished road
Default Vacum Resevoir ball
Does anyone know were resevoir gets its vacuum from. I cant find a nipple anyplace on the plenum other then brake booster and vac line from resavoir is just three feet of unattached tube.....
Thanks, Jeff.
Old Apr 12, 2016 | 08:51 PM
AJBert's Avatar
It attaches to a tee inboard of the brake booster. Sounds like you have two lines hanging loose probably below the brake booster, unless the previous owner decided to reroute things and deleted the reservoir.
Start the engine and put your ear between the brake booster and the rear of the engine and see if you can hear a hissing sound. If you can and can find the tee, that is your culprit. This is on a 2nd gen, if that is what you have. Not sure on the 1st gen.
Old Apr 13, 2016 | 01:53 PM
Thanks will check
Jeff
Old Apr 18, 2016 | 02:54 PM
Thank AJBert the t was disconnected but that was not the problem. Bad out of the box Chinese TPS. Runs great ! Got a delco in there now, thanks to you and Chuck!
ChevyGirlBlazerRacer
Jan 11, 2014 10:38 AM
MysecondChevy
Aug 3, 2009 02:56 PM
BIGred4X4
May 24, 2009 02:46 PM
banshee386
Apr 14, 2009 07:15 PM
ken01blazer
Dec 29, 2008 08:25 PM
