Vacume line replacement
Old Jan 30, 2015 | 10:30 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Question
For 1 thing Im missing the vacume canister.Can plug that line off so that I can at least get this thing to run?As for the other number I`ll get them Saturday when it warms up.Theillustrations are of great help except the only difference is that my 3 connector is round not rectangle.That doesn't matter probably it just a drawing correct?
Also I need to know to size of the vacume line and how much to buy.A shop is going to do the work for me.
Old Jan 30, 2015 | 11:00 AM
The reservoir helps the vacuum system to maintain the actuators in the selected position, if there is a slight vacuum leak in the system. In a pinch you can cap it off.
The drawing is for illustration purposes only, (I'm obviously not an artist )
Old Jan 30, 2015 | 07:21 PM
Bagherra's Avatar
Bagherra is on a distinguished road
Are all the vacuum lines the same size? Becuz of my 4wd issues, that's another thing on my list of things to do....
Old Jan 31, 2015 | 09:55 AM
Exclamation
Nevermind Sorry chuck I didn't look at your diagram with my eyes open thanks for the info I appreciate it.
Old Jan 31, 2015 | 04:07 PM
Vacuum lines are 5/32" & 7/32". They won't fit on the wrong way, so you can't screw it up
Old Feb 1, 2015 | 08:32 AM
I was able to buy the 5/32 line but our stores are out of 7/32 so I have to wait till they get more in stock.With storm on the way I will have to wait till probably Tuesday.
Old Feb 16, 2015 | 03:00 PM
Figaroman1's Avatar
Figaroman1 is on a distinguished road
Default Vacuum diagram same for 1999 Trailblazer???
Would this be the same diagram for 1999 trailblazer???
[/QUOTE]
Old Feb 16, 2015 | 08:17 PM
Figaroman1, only if you have the 3 button, NV233, 2 speed selectable transfer case. The 4 button, NV236, Auto 4WD does not have a vacuum switch on the transfer case.
Old Feb 17, 2015 | 05:24 AM
newguy's Avatar
I`m so happy I got rid of the vac actuator setup. Alot of snow in the northeast and been using 4 wheel drive every other day. Hasnt failed me yet
Old Apr 8, 2015 | 11:04 AM
Question
Guys question on the vacume lines on the engine can I use the same size line instead of all different sizes?
