Vacuum actuator
Covered in many other threads. How far is the cable being pulled? It needs to move around a 1/2" to engage the front axle. If that still doesn't do it, then you likely have an issue where the cable connects to the shift fork in the front axle.
the cable is definitely being pulled far enough i checked by starting the truck removing the battery and tray then having my cousin engage the 4wd and it's pulling it far enough. I am going to my dad's house later i will check where the wire goes into the fork. i will tell what i find.
i just have a question. I have not been able to pull apart my differential and look at the shift fork yet but if it is stripped or worn could i possibly weld the 2 shafts together or would that cause a major problem.
It most definitely will be a problem. You need to pray that it did not make its way into the HVAC system or you are in for a LONG cleanup process.
The problem stems from two issues. A leaking input seal on the front of the transfer case (where it connects to the back of the transmission) and a bad vacuum switch on the transfer case. The leaking seal on the front of the transfer case allows the transfer case to become over filled. The bad vacuum switch on the transfer case allows the transmission fluid that has over filled the transfer case to be pulled into the vacuum system.
Remove the fill plug on the back of your transfer case. If fluid pours out, the input seal is bad.
On the NV136 transfer case in the Bravada, sounds like the clutch is bad. I would be looking for a replacement NV136 for it.
http://www.rockauto.com/catalog/moreinfo.php?pk=1118669
I see no reference to the NV136 but Rockauto lists this for '02 Blazers. Do you think the faulty seal caused the vacuum switch to fail or the failed switch caused negative pressure in the t-case causing it to suck in fluid? Do you have any reference drawings on the transmission / transfer case that might show this in detail?
By taking off the shift mechanism-cover on the right side of the differential (3 bolts), you can test if the cable is still on the shift fork by pulling on the housing. If the housing comes apart completely(so no attachment no more),then probabely the cable -clip on the shifter loosened.It is held with a sort of clip-spring. Try to push the cable back in by holding it through the hole of the switch on the housing ( which You can take off easely)with a nose plyer, if the cable pops back in and stays in by pulling (and someone trying the hubs)o.k. If still no engagement, You probably have to change the CARRIER conector (oem # 26047584). This is a mayor job but "do-able"
ok i have been trying for a while to get on here but i tore my differential apart thinking maybe there was some broken thrust washers inside. took it apart, nothing. put it back together checked everything again and still no 4 wheel drive. i looked at all the parts inside and everything seemed fine. this thing is just starting to be a hassle.
