Vacuum Actuator To Weak
Old Dec 17, 2009 | 04:12 PM
andryscha's Avatar
andryscha is on a distinguished road
Default Vacuum Actuator To Weak
Hi, my blazer 95 has a new vacuum actuator. it worked for few days now it is to weak to put on the 4 x4 in the front axe. It works but to weak?
What can I do ? What have I to check?
Please help me.
thanks.
Old Dec 17, 2009 | 05:10 PM
ABN31B's Avatar
check your new accuator for possible tears, cuts, etc.
check your vac lines. after 15 years dry rot should have eatten a few.
check the connections where you hooked up said lines. if you re-used old lines, they may be too old to 'stretch' correctly. Now you have limp connections and vac leaks.
that should get you started anyway.
Old Dec 17, 2009 | 05:32 PM
andryscha's Avatar
They vac lines looked like new. where is the pump? or has the blazer a pump to produce the vacuum?
soory for my english, I am from Germany and for a work and travel Visa here in Canada.
bought the blazer and I like it very much.
so please help me.
thank you.
Old Dec 17, 2009 | 07:18 PM
Vacuum is supplied by the engine. You can test the vacuum supply by connecting a vacuum gauge to the line at the actuator with the transfer case in 4wd. Note the reading and then connect the gauge to a vacuum port on the engine. There should be very little difference between the two readings.
Old Dec 17, 2009 | 07:49 PM
andryscha's Avatar
thank you very much will test it tomorrow.
Crestwood1001
Jun 2, 2009 09:02 PM
markrd
May 8, 2009 01:39 PM
sasquatchfound
Sep 21, 2008 12:07 PM
patterrr
Oct 24, 2006 03:50 PM
blazinloud
Engine & Internal
Oct 17, 2006 05:39 PM
