Vacuum Hose Help
Old May 15, 2009 | 06:47 PM
65longroof's Avatar
65longroof is an unknown quantity at this point
Sorry no pic
Old May 19, 2009 | 07:46 PM
GotYoNacho's Avatar
GotYoNacho is an unknown quantity at this point
Got everything hooked up but the top line in the second pic
From the diagram looks like the line from transfer case to the thing under the battery. Any pics of where it hooks in? I couldn't find the plug for it.
Old May 20, 2009 | 08:35 PM
bugi_ftw's Avatar
bugi_ftw is on a distinguished road
Originally Posted by 65longroof
No problem I'm glad I could help.
If they are cut you have a couple of options, 1) Go your local junk yard and get that section out of another truck, it is only about 8 inches long then there is a connector. 2) you may be able to push them back into the control switch. 3) use small heat shrink tubing to reconnect the ends.
When I had to fix mine I got an extra from the local yard and used heat shrink tubing to hold them together, there isn't a lot of vacuum so you can get away with it. I may have a pic that shows my lines I'll look.
Good luck
OK, bought a new set of hoses from ebay, anyone have a diagram where they go? Thanks again.
Old Jun 19, 2009 | 12:24 PM
MikeMccalla8's Avatar
MikeMccalla8 is on a distinguished road
Default hellp!
hey, i am having the save problem my air only comes out of my defrost and feet, but i can change the air for low to high. so i read some of the forums and started checking out my vacuum hoses, well i found that the line coming from the vacuum ball to behind the intake manifold is not plugged in at all and i cannot find where it plugs in because its so hard to see back there. i have a 95 blazer. can anyone tell me where it plugs in at?
Old Feb 17, 2010 | 10:29 PM
954x4's Avatar
954x4 is on a distinguished road
its hard to really see but it is on the passenger side close to the top will tyr to take a pic if you look from the top down you can see it,it will also help to have it running and feel back there for it
sparkovich
Jan 22, 2013 09:48 PM
sillyak
Nov 4, 2012 04:12 PM
86TransAm
14
Dec 13, 2011 07:46 PM
fahli
Mar 1, 2011 06:38 AM
rob1621
Apr 3, 2008 08:55 PM
