Vacuum Hoses and Transfer Case Vacuum Switch
Hi All, I have a 2000 Chevy Blazer LT, V6, Push button 4WD
The 4WD quit working recently so I did some research on the forum. I ended up back at the transfer case thinking that my issue had something to do with vacuum lines and the Transfer case vacuum switch.
What I found were two vacuum lines disconnected and I was unable to find the vacuum switch. I have attached two pictures, one for each of the vacuum lines I found. The vacuum line with the end still attached I was able to track as far as the motor area by the tranny dipstick. The other line leads to a metal line above the tranny.
I am unsure as to what to do next, I can't find the vacuum switch on the transfer case or a third vacuum line that I think should be there based on my research. Any guidance, thoughts, questions, or suggestions would be appreciated.
How many buttons are on your 4WD switch? If you have three buttons then you have a transfer case with the vacuum switch on the case. If you have four buttons then you have a totally different transfer case that doesn't have the vacuum switch on the transfer case; it's on the firewall.
Just looks like 3way vacuum switch for the 3 button trucks. mount on the drivers side top of the transfer case
http://shop.advanceautoparts.com/p/d...=vacuum+switch
