Vacuum line sizes
So I have to replace my heater core in my 97 blazer. I figured since I am going to have the whole dash out I might as well replace the vacuum lines behind the dash, I have heard all kinds of suction/hissing noises back there so I am assuming its a vacuum leak and hoses are so cheap. But I do not know the sizes I need to get. If anyone knows please let me know =) thank you very much.
Agreed. If you have 4wd, and your transfer case vacuum switch has never been replaced, you may have t-case fluid in your lines, which can provide some unwanted lubrication around the line connections. Vacuum will seal less effectively at the connections, possibly causing leaks.
ok, autozone has a few diff ones all listed for my truck. Will this one work?
Duralast/Transfer Case Switch (SW3467) | 1997 GMC Jimmy 4WD 6 Cylinders W 4.3L SFI | AutoZone.com
Xavier
Apr 11, 2014 11:49 AM
igs4dragon8
May 14, 2013 09:52 PM
