voltage meter
Old Jul 27, 2011 | 09:04 PM
chefchap19's Avatar
chefchap19 is on a distinguished road
Default voltage meter
SO i have a 1997 chevy blazer yesterday she crapped out on me and completed died went to try and start again and it just clicked like a dead battery so i knew my batt and alternator were on thier way out so i replaced both it runs fine now but i am concerned because my volt meter on the dash is reading 9v and before it had its problem it read a norm 14v
any thoughts would be great ty
Old Jul 27, 2011 | 11:27 PM
stlwaco's Avatar
stlwaco is on a distinguished road
have the alternator tested. you might have got a bad one. Could also be a bad fusable link.
not sure if they had one on the 97s.
Also, please use punctuation. it makes reading you post a lot easier.
Old Jul 27, 2011 | 11:31 PM
xgiovannix12's Avatar
Might be a defected alternator go get it tested at the auto parts you bought it at
Old Jul 28, 2011 | 06:31 AM
chefchap19's Avatar
Default ty
Sorry about the punctuation, I had just got done with a 13 hour work day lol
I will get that alternator checked out today and seee if that was the case.
Was wondering isnt there a way to test one with a multimeter?? to see if it is pumping out a current
ty
Old Jul 28, 2011 | 06:35 AM
marksoftball's Avatar
marksoftball is an unknown quantity at this point
My volt meter on my dash has not been telling me
the truth for the past 4-5 years. I never figured out why.
I figure a ground or bad connection.
I bought an inexpensive volt meter for about 7-10 dollars
that you can plug into your cigarette lighter. I have relied on it
for the proper reading. My dash may say 10 but the volt
meter in the cigarette lighter reads 14. An easy way to see
if the readings agree with each other. I have depended on it
for the proper readings and I no longer care what the dash does.
Just a thought.
Mark
Old Jul 28, 2011 | 10:41 AM
stlwaco's Avatar
ty
You can use your multimeter at the battery posts and output terminal on the alternator while the engine is running. See what it tells you. But you also want to get the alternator tested to make sure it is putting out the correct amperage.
Most multimeters will blow their fuse if you try to read an alternator's amperage. You will have to use the machine at autozone with the amp clamp.
Brian_D
Sep 21, 2013 07:37 PM
2001Blue
Dec 31, 2010 12:16 PM
zombiewoof
Feb 25, 2008 06:51 PM
drperry
Mar 9, 2007 09:57 PM
dropd4door
Feb 21, 2006 11:43 AM
