Wants to stall under throttle at first start up
Thanks Rusty, I sure hope that it is. This has been kicking my butt. It needed so much repaired but these last few gremlins have been hard for me to chase down. I’ve never taken a vehicle to a shop unless it was warranty work but I decided to take this one early on and was disappointed.
Its a shop we use for work and I thought they would be a reliable repair. They said it was the injection system and replaced that and a few vacuum lines. It improved slightly and got rid of the hard start but still not enough. So I have been scanning and replacing trying to narrow it down. Budget is quite thin at this point and my son is a bit discouraged.
Going out to do the leak down test shortly.
It is normal for fuel pressure to be in the sixties while the pump is on and to drop when the pump turns off. While the pump is on your are looking at regulated fuel pressure if the pump and system are in good working order. As soon as the pump turnes off the pressure will drop but must hold 55 or more for 10 min. Now you are checking to see if the system is leaking.
George
George
