Wants to stall under throttle at first start up
Old Nov 3, 2018 | 12:53 PM
  #71
ajfetterman's Avatar
ajfetterman is on a distinguished road
Well it’s the dangest thing. I went back out to connect my scanner to see if I had the option to see the misfire count, that answer is no. But, I started it up to check the live data again and get the fuel trims and it sounded pretty smooth.
So I throttled her a little and it still sounded smooth. Now I was intrigued so I backed it out and took a short test drive, then a longer one. It’s running great now and doesn’t have a misfire.
Im happy but not convinced quite yet. I will have to run it a few days and see what she does. Maybe it was just a gremlin.
Old Nov 3, 2018 | 12:54 PM
  #72
[QUOTE=ajfetterman;698097]
Im happy but not convinced quite yet. I will have to run it a few days and see what she does. Maybe it was just a gremlin or an answered prayer.
Old Nov 10, 2018 | 08:04 AM
  #73
It’s been a week and she’s been running just fine.
Onlly code left is P0420 which from what I gather is typically exhaust. It could use and exhaust so that is next on the list. At least we are getting some road time out of it now.
Still have this weird thumping / pumping type random noise from the rear. It will happen at random times and doesn’t seem to have a pattern.
Thank you guys for your help and if this other noise sounds familiar, give me an idea.
Old Nov 10, 2018 | 09:11 AM
  #74
GeorgeLG's Avatar
Your going to want any problems with leaking coolant, O2 sensors or misfires cleared up before you install a new cat converter so you don’t kill the new one. Glad it’s running better.
George
Old Nov 10, 2018 | 09:14 AM
  #75
Everything is cleared up besides that 420 code. Is that the cat? I know there are some holes on the weld leaving the cat.
Old Nov 10, 2018 | 09:22 AM
  #76
GeorgeLG's Avatar
It’s the cat efficiency or the O2 sensors mistakenly claiming a lack of cat “conversion”. One quick test is to shoot the cat in front and behind with an IR gun to see if it’s converting. A pressure gauge in the front O2 sensor hole to see if it’s getting plugged from crumbling cat material or looking at the O2 sensors on live data to see if they are outputting correctly.
George
92s10blazer
Feb 19, 2015 05:43 AM
fletch125
Dec 23, 2014 09:50 PM
MXer746
Jun 6, 2011 02:34 PM
jamez70
Oct 1, 2009 12:41 AM
burningsun
22
Apr 16, 2009 09:12 PM
