washer popping fuse? *FIXED*
Old Aug 11, 2007 | 10:47 PM
davtak's Avatar
Default washer popping fuse? *FIXED*
I was driving home from work the other night and went to use my wipers and they worked fine. I then went to wash the window and the wipers stopped 1/4 way up the windshield. Come to think of it, no washer fluid came out. Hmmmm, I'll have to check that. Anywho, I pulled over and after a few checks, I found that I fried the fuse. I took it out and replaced it with a spare. I turned the wipers on and they worked. I stsrted driving home again and about 10 minutes later, I tried the washers again and "POP!". There goes another fuse. What could cause that to do that. A frayed wire to the washer fluid pump maybe cause no fluid came out of the nozzles. I'm gonna check a few things next time I get a chance. For now, no washing my windshield with the washer fluid. I need my wipers cause it rains on and off here and you never know.
Old Aug 21, 2007 | 02:00 PM
Default RE: washer popping fuse?
*Moved to Gen Tech - 2nd Gen Tech*
Have you tried to disconnect the washer motor and see if it still pops the fuse?
Old Dec 7, 2007 | 09:20 PM
davtak's Avatar
Hahaha, I forgot about this until I went to go and use the washer tonight and popped the fuse. Doh! The fuse doesn't pop when I use the rear washer, just the front. The wipers work fine until I try the washer, then pop! Where is the washer motor?
Old Dec 7, 2007 | 11:30 PM
Chevy Lover's Avatar
Washer pumps are located on you w/washer bottle in the eng compartment.
Old Dec 8, 2007 | 10:14 AM
davtak's Avatar
That's what i thought. Just wanted to make sure. What on the pump would cause this to happen. The washer works fine on the back window though. When the fuse pops, the wipers don't work at all. Well, the fronts don't. I had to pull over this morning and use a bottle of water to wash my windows off.
Old Dec 8, 2007 | 08:39 PM
davtak's Avatar
Default RE: washer popping fuse? *FIXED*
still can't find out what the problem is. Any ideas?
Old Jan 2, 2008 | 12:02 PM
davtak's Avatar
I found the problem and fixed it. The heat shield was resting on the wires and had stripped some of the insulation off and exposed the wire. I replaced the wire and routed them away from the heat shield and they work great now.
Old Jan 2, 2008 | 12:20 PM
Glad you got it fixed! Wiring problems are never any fun.
Old Jan 2, 2008 | 01:53 PM
Glad you got it fixed, it must feel food to stick with it til you get the problem resolved.
Old Jan 2, 2008 | 03:27 PM
junkmonkey's Avatar
junkmonkey is an unknown quantity at this point
It is often the case where the weirdest problems are caused by the simplest of failures (exposed wire), but the devil is in finding that darn thing. Electrical problems are always buggers to find. Glad you got it resolved.
In a similar vein, one of my guys was complaining that his company truck "Chevy Silverado" was acting up electrically. Took it to the dealer and they couldn't pinpoint the problem (intermittant thing). They finally found that a little critter had taken up residence in the under hood fuse box and chewed off enough wire insulation on a couple wires to causing intermittant shorting caused by road vibration. An eviction notice and a little cutting and pasting and he was back in business ($475.00 dollars later).
BlueRyde
Jan 19, 2011 10:56 PM
jaygjay
Feb 15, 2010 10:54 PM
bgillette78
Aug 11, 2008 07:08 AM
myblackblazer
Nov 2, 2007 03:48 PM
ivannj
Jun 30, 2007 07:25 PM
