Website Problems and Suggestions Need help using the website? Ask here. Have a suggestion to make us better? Tell us here.
windcreen washer pump fuse
Old Feb 15, 2010 | 09:25 PM
jaygjay's Avatar
jaygjay is on a distinguished road
Talking windcreen washer pump fuse
My windscreen washer pump will not work. It works on the bench. I dont believe the pipes are blocked. I am getting now power to the pump plug. I cannot not locate the fuse. The diagram on the fuse box is wrong. Any ideas please, how this system works,
regard jaygjay
Old Feb 15, 2010 | 10:32 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
What are we working on? Year of vehicle would help. If you're getting power to the plug and it works on the bench then you have a bad ground or a bad connection at the plug. The washer should come off your wiper fuse but I'm not sure what year you have.
Old Feb 15, 2010 | 10:38 PM
jaygjay's Avatar
Default washer pump fuse
Yes dude, sorry. The year is 2000. The wipers work fine, there is no power at the pump plug when i twist the wiper stalk on the steering column. Just unsure where the fuse may be to check, thankyou kindly
Old Feb 15, 2010 | 10:54 PM
There should be a small plastic cover that just pulls off at your wiper control (stalk) and you can check to see of you have power to the wiring that goes to the washer pump. I think that your system works like this. You can check voltage right at the wiper switch (stalk as you call it). When you hit the washer switch you should have voltage at the Orange and Pink wires. Orange coming in and Pink going out to your washer pump. All this is controlled by the solid state part of the wioer motor and module.
BlueRyde
Jan 19, 2011 10:56 PM
Good_Chevy
Jan 15, 2011 11:05 AM
davtak
Jan 2, 2008 03:27 PM
jpbt1
Aug 2, 2007 05:03 PM
kaindragoon36
Mar 25, 2006 04:22 PM
