Water in #2 cyl and oil
Ive replaced the intake manifold gasket twice on a new engine.
the intake is original, could it be cracked allowing water in the #2 cylinder and also in the.oil
I did it twice to ensure i didnt mess up the 1st time. I had water in the oil a few minutes after starting the motor.
i just finished this build, i dont have any confidence in the machine shop i choose to do engine work. My thinking is the head is cracked, as the compressshop returned 1 vortec, 1 non vortec. I will do compression check this afternoon
The engine shop was told to check heads for cracks and valve job as needed, r/r engine and crankshaft.
they lost my crank shaft, replaced with a new one from oriellys.
i was given the heads, upon installing, i found the vortec differences between them. Confronted engine shop as to employing a crackhead, they ordered me a new reman head. Again, from oriellys. I have no faith whatsoever in the work i paid for 2 years ago. Im only now ready to drive this vehicle.
please see build under my gallery of pix. Almost 3 years on the making.
Mater is a 54 dodge panel truck on a 97 4x4 gmc jimmy 4dr chassis.
everything new or refurb.
Thanx 4 any and all help.
Boudreaux
97 s15 jimmy 4x4 4dr chassis
97 4.3L w/rear air from escalade
Boudreaux
That’s a nice looking truck, really cool.
So the long block has been rebuilt, the heads have been rebuilt/replaced, the LIM gaskets have been replaced twice, and the rebuilt motor is at zero miles but has water in the #2 cylinder and water in the oil?
Who assembled the heads to the block and who did the two LIM gasket replacements?
Did this rebuilt motor have any trouble free hours after all this work or are you in essence still trying to get the work finished successfully?
George
George
Water in oil
Did this rebuilt motor have any trouble free hours after all this work or are you in essence still trying to get the work.
George
George
i brought newly assembled engine to temperature a few times checking this and thaandran perfectly.. An hour of run time total over a month. Noticed white smoke and a small miss developed.
Found milky dipstick, water shooting out of #2. 1st lim gasket done, ran about 15 minutes clean and perfect
Same gig again...
