Water noise.
Old Oct 11, 2008 | 10:20 AM
rmv42158's Avatar
rmv42158 is an unknown quantity at this point
Default Water noise.
Hello Again. Every now and then i hear water dripping form inside the dash board when i take off from a light. Happens only when the a/c or heat is on. There is nothing dripping in the cabin, the underneath of the dash is not wet, and nothing out of the ordinary under neath. has anyone had this happen?
Thanks
Old Oct 11, 2008 | 11:37 AM
Default RE: Water noise.
If it is a water flowing noise, this is commonly caused by a restricted heater core. Sometimes a flush can cure this condition, but if it has been there for awhile, your core may be corroded to the point where flushing it may open up a leak.
If it is truly a dripping noise... That is odd...
Old Oct 11, 2008 | 11:57 AM
dBsound's Avatar
dBsound is an unknown quantity at this point
Check your antifreeze level, and make sure it's not low. My water pump was going out last fall, and I kept hearing a gurgling sound. Also, heater wasn't doing much at all. I never smelled antifreeze, and never saw any leaks on the driveway, so my water pump died a very slow death.
mav06
18
Jun 30, 2013 05:40 AM
OI5HI
Dec 27, 2009 04:29 PM
jaiburnam
Feb 15, 2008 03:32 PM
arin
Apr 13, 2007 11:26 AM
picken_grass
Aug 1, 2006 04:54 PM
