Water pump
Old Dec 15, 2010 | 12:43 PM
epederson's Avatar
epederson is on a distinguished road
Default Water pump
I'm replacing the w/p on my 98 blazer today. What is the easiest way to remove the large nut retaining the fan/clutch assembly?
Thanks
Eric
Old Dec 15, 2010 | 02:59 PM
s14sh3r's Avatar
Buy, borrow,or rent, the tool that's designed for it. I changed my water pump a month ago and tried to do it without the tool. I ended up knocking a good sized chunk out of my knuckle and it still wouldn't come loose. I ended up borrowing the tool from guy who owns a shop next to me and it came off pretty easily.
Old Dec 15, 2010 | 03:40 PM
step66's Avatar
Hey! Another way to do that job without the special tool is to remove the pump with the fan still attached,then use a "strap wrench" ( a tool used in irrigation and other piping systems ) worked like a charm for me...
Old Dec 15, 2010 | 03:46 PM
stlwaco's Avatar
stlwaco is on a distinguished road
Last time I did it was with a strap wrench on the water pump pulley.
Old Dec 21, 2010 | 10:29 PM
Camaro98's Avatar
Camaro98 is on a distinguished road
All I had to do was hold the pulley in place by putting a 13mm box-end wrench on one of the four pulley bolts, and then spin the large fan clutch nut loose with a large adjustable wrench. No problems.
Didn't work the same way for putting it back on, though.
chipjumper
15
Dec 14, 2019 08:49 AM
BouncingRadical
14
Nov 27, 2015 12:30 AM
shesrdy2laff
Oct 14, 2009 12:46 AM
blazermanxx
14
Mar 27, 2006 12:25 AM
myetman
Jul 4, 2005 11:56 AM
