water pump keeps leaking
Old Mar 16, 2006 | 06:21 PM
blazermanxx's Avatar
blazermanxx is an unknown quantity at this point
Default RE: water pump keeps leaking
UPDATE!!!
so i solved all the problems with the car as of right now. I found out that the thermostat would not open because when the water pump blew out it sucked in alot of air. and there for too much air in the system. So i jsut had to purge out all the air and it works great now.
Thanks for all your guy's help!!
Old Mar 16, 2006 | 06:50 PM
4lowlife's Avatar
Glad to hear it's fixed.
Old Mar 16, 2006 | 10:03 PM
Hanr3's Avatar
So I missed the part where it was getting hot, or did you leave that little detail out?
Old Mar 27, 2006 | 12:06 AM
frankjc's Avatar
frankjc is an unknown quantity at this point
This sounds familiar. I should check mine. I changed the pump about a year ago, and I saw some coolant under my car. I will check those bolts, and my fan clutch.
Old Mar 27, 2006 | 12:25 AM
blazingsadle's Avatar
blazingsadle is an unknown quantity at this point
The belt thing is my bad, but I have a regular rotation 4.3 with v belts and full width serp also in a blazer, on the same engine. V8 pump. V8 timing cover. Guess not knowing what I am supposed to do works just as well. Camaro?
craig1319
23
Jul 6, 2018 11:26 PM
mwilkinson
Apr 4, 2010 12:54 PM
98jblaze
Sep 29, 2008 11:03 AM
flabob1
Oct 17, 2007 02:46 AM
93LT
Nov 11, 2006 11:57 PM
