Water Pump Removal
Water Pump Removal
A week ago I noticed coolant leaking/seeping from the water pump on my 4.3L 01' Blazer. I know the job requires the Fan-Clutch Removal tool. But does anyone know if the large nut that holds the fan-clutch on is regular or reverse thread ? Any helpfull advise or tips from anyone who has done this before ?
[IMG]local://upfiles/8645/4E8F1C3B56C649C29CC441964B53287A.jpg[/IMG]
[IMG]local://upfiles/8645/98E7664BB06B48FFA29FBD427FE255A9.jpg[/IMG]
RE: Water Pump Removal
It's (regular) right hand thread.
There have been times when I didn't have the correct tools to remove the fan clutch and I have used a large cresent wrench and a 2lb hammer. ( not the reccomended method)
I left the belt on for some tension, then put the wrench on the nut and smacked the handle of the wrench to loosen the nut. It has to be a very quick, hard and accurate hit. If you have any doubts, rent the special tools.
For installation, I just reversed the procedure. I also applied a couple of drops of thread locker on the threads for assembly.
Thanks, I already rented the tool but wasn't sure about the thread. Looks like it's a some what easy fix. We'll see how it go's this weekend.
BouncingRadical
14
11-27-2015 12:30 AM
ravenhurst
28
12-01-2014 08:43 PM
