Water pump replacement
Old Jul 4, 2005 | 11:56 AM
myetman's Avatar
myetman is an unknown quantity at this point
Default RE: Water pump replacement
Well job completed!
All went well with the exception of the fan.
As noted by Zero Psi.
Disconnect the neg battery cable.
Removed the air cleaner and hose.
Pull the top of the fan shroud off.
Using a BIG 1 1/2 adjustable and 2.5 LBS hammer I loosened the clutch fan.
Removed the Fan.
Removed the belt
Removed the water pump pulley
Removed the pully above the water pump, easier access to top hoses.
Drained rad via nipple on bottom left...very messy.
Pulled hoses off pump.
Removed 4 bolts on pump.
Clean block.
Applied gasket glue and gasket.
Installed new pump, hoses.
Reinstalled pullies.
Installed new belt.
Installed Fan.
Installed Shroud.
Installed air box.
Reconnected battery.
Filled rad, started, leak checked.
Topped rad.
Went to Beer store.
Thanks for all the help. Total time was about 3 hours.
Mark.
rxjimmy
Apr 14, 2015 09:49 AM
bdemutis
Mar 9, 2013 04:30 AM
ComputerNerdBD
Nov 28, 2011 05:08 PM
racsan
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Aug 27, 2011 07:53 PM
Depth505
May 17, 2011 09:36 PM
