Waterpump Pulley Squeek
Old Aug 21, 2008 | 08:59 PM
Jharper's Avatar
Jharper is infamous around these partsJharper is infamous around these parts
Default Waterpump Pulley Squeek
My waterpump pulley squeeks all the time when the motor is cold, what do i do to fix this? i sprayed the pulley with WD40 and it helped but then the next time it still squeeked, only does it when i first start it up and drive about 5 miles then it stops, and then tonight i sprayed belt dressing (suposed to stop squeeks) and that didnt help one bit. what should i do? or is there a bigger problem?
Old Aug 21, 2008 | 09:01 PM
WolfPack's Avatar
Default RE: Waterpump Pulley Squeek
Is your belt on correctly? Also, if you look at the pulley, it should be dark colored. Do you see any silver on either side of the belt? If the belt is mispositioned, you might have a tensioner issue...or another pulley thats off/failing/weird
Old Aug 21, 2008 | 09:05 PM
Jharper's Avatar
Belt is on correctly, and its a brand new belt after the rebuild less than 4k miles ago, i was thinking the tensioner, but how big of a deal is that? also i was told it could be the bearing.
Old Aug 21, 2008 | 09:09 PM
WolfPack's Avatar
I suppose it could....that would actually make sense if belt dressing or lube didnt fix it at least temporarily..
But when I switched out my belts, I actually took off the tensioner and put it back on incorrectly (rookie mistake)...and I had the same symptom...squeak at start up, but after a few minutes it went away. After I repositioned the tensioner and got it set up properly, no squeak!
Old Aug 21, 2008 | 09:10 PM
Jharper's Avatar
Alright thanks Wolfpack, how hard is it to change the tensioner?
Old Aug 21, 2008 | 09:14 PM
WolfPack's Avatar
Pretty much just the one bolt. It can be tricky getting the bolt back in though...it has to fit through a couple little holders/brackets it feels like like. Also when taking it off, the spring tension will all the sudden let go...it made me jump the first time.
Just make sure the metal peg is above the block....I put the little peg in the hole it looks like it might fit in...but...doesnt go there
Old Aug 21, 2008 | 09:33 PM
I'd get a better belt. Lower quality belts will always squeal and it will only get worse.
Old Aug 21, 2008 | 09:36 PM
WolfPack's Avatar
que: GATORBACK.
woo!
tb402
Jul 19, 2010 09:31 AM
Kirk-NJ
Feb 19, 2010 07:45 PM
axeman
Aug 11, 2009 09:24 PM
old1999
Jan 14, 2009 04:46 PM
Mickeymouse
Mar 3, 2008 02:16 PM
