Weird climate control problems
Old Mar 26, 2023 | 08:57 AM
Jmack's Avatar
Jmack is on a distinguished road
Default Weird climate control problems
1998 Blazer 4wd 4 door
Never had this problem on any of my cars. I put the heat on the lowest setting. I think it’s 66 degrees, one degree above horizontal. When it warms up, it feels over 70, maybe 75 to me, regardless of the temperature outside. My shop checked the temperature, its normal, said there are no vacuum line leaks. Normal?
Old Mar 29, 2023 | 01:28 AM
99Moneypit's Avatar
99Moneypit is on a distinguished road
I'm not sure what the problem is exactly, is it blowing warmer air than you'd like or do you feel it's not turning off at the correct temperature? If it's the latter, the ambient air temperature sensor you're looking for is behind the radio to the right in the HVAC duct I believe. The zero dollar fix is to crack a window and draw some of that warmer air out or just manually turn off the fan itself.
vandyatkins
Apr 27, 2018 05:41 PM
rpare01
Oct 8, 2013 07:06 PM
gojorg
Nov 18, 2011 08:55 AM
walleye seeker
Oct 14, 2010 06:52 AM
toaks
Aug 12, 2008 07:56 PM
