Weird gas tank size?
Old Apr 25, 2014 | 10:04 AM
do0m's Avatar
do0m is on a distinguished road
Default Weird gas tank size?
Hello everyone,
I bought a used 2001 blazer ZR2 a couple of months ago and from what Ive been reading, it SHOULD have a 19 gallon gas tank. Yet when I fill it from E with the gas light on I only see it taking 12 gallons to top off. I'm assuming the gas tank was replaced considering how small the tank is, unfortunately the previous and original owner is not returning my calls about it.
Could the gas gauge be busted, or is 12 gallons the norm?
Old Apr 25, 2014 | 10:48 AM
TrevT1's Avatar
TrevT1 is on a distinguished road
My gas guage doesn't work either. Common problem with the Blazers. Just track your miles driven and keep an eye on it. My low fuel light seems to come on after I use about 14 gallons. If the tank isn't crushed , and wasn't replaced, my guess would be that the fuel level sending unit is going out. That's what usually causes the problem.
Old Apr 25, 2014 | 10:52 AM
do0m's Avatar
Will do, and thanks for the reply!
Old Apr 25, 2014 | 11:12 AM
dobyken's Avatar
dobyken is on a distinguished road
I'm pretty sure that's normal. There's quite a large reserve of gas in the tank even when your low fuel warning lights up. I've never put in more than 13 gallons since I bought mine new in 99.
Old Apr 25, 2014 | 02:13 PM
kf4eyr's Avatar
kf4eyr is on a distinguished road
doesnt the 2 door models and the 4 doors have diffrent sizes of tanks? when i replaced my fuel pump on my 2001 there was a diffrence because 2 door is under frame and 4 door in different place..... just a thought
Old Apr 25, 2014 | 03:25 PM
TrevT1's Avatar
4 doors take 18 gallons, where 2 doors take 19 gallons.
Old Apr 25, 2014 | 05:48 PM
rexazz2's Avatar
if you really want to test it carry a full gas can along until you run out
I know the gauge on my 05 2dr is not accurate at all , I don't usually let it ever go under a 1/4 regardless
Old Apr 25, 2014 | 08:03 PM
er0ck273's Avatar
er0ck273 is on a distinguished road
when i first got my truck, the owner just fixed this. what makes the gauge end up not working and such a common problem?
Old Apr 25, 2014 | 09:46 PM
TrevT1's Avatar
The fuel level sending unit goes bad. From what I understand (correct me if I'm wrong) you have to drop the tank to replace it, and it is attached to the fuel pump. Mine doesn't work either. In fact, the harder I accelerate, the more gas the guage says I have in my tank. Lol
Old Apr 25, 2014 | 10:11 PM
er0ck273's Avatar
yea you do have to drop the tank, which is why most people say forget it lol
Smc
Nov 14, 2013 04:46 PM
georgemejiajr
Oct 7, 2011 08:28 PM
wjdjake
Jul 17, 2011 02:06 AM
Blazer man1998
Apr 29, 2007 08:37 PM
2001blazer
Jan 24, 2006 06:16 PM
