weird noise from breaks
Old Oct 30, 2010 | 01:12 AM
onder's Avatar
onder is on a distinguished road
Default weird noise from breaks
i have a 2dr 4wd 2000 blazer. i recently replace my breaks and today when i stop at the red light, i heard a really weird noise coming from the front left side. i realized it it does it when im going slowly and breaking. the sound is like pad is stick to the rotor and doesnt want to let go. can anybody help me plz
Old Oct 30, 2010 | 07:29 AM
Have you checked your brakes? You could have worn pads. It may be normal wear or you may have a problem with the caliper sliders.
Old Oct 30, 2010 | 11:31 AM
onder's Avatar
pads and the rotors are brand new
Old Mar 10, 2011 | 09:03 PM
onder's Avatar
the mechanic didnt tightened up one of the screws on the pad so it was moving when i push the brakes
Old Mar 11, 2011 | 05:16 PM
step66's Avatar
I hope you replaced the caliper mounting bolts when you did the brake job and used anti-sieze as well! sounds like a possible caliper problem,but if you say the pads are moving...but I still suspect a caliper issue! Easy swap! Good luck! step66
Old Mar 12, 2011 | 09:36 AM
blazinloud's Avatar
real good mechanic you got there
last time id go to him
Old Mar 16, 2011 | 01:18 AM
leeroy74's Avatar
leeroy74 is on a distinguished road
Just replaced the rear rotors and pads two weeks ago. One of the caliper bolts was seized and it broke off had to replace the caliper bracket. I also had to replace the caliper since it was seized as well. Ask your new mechanic to check the caliper bolts. Think I paid 9 bucks for a set of new ones and lubed them up good!
Old Mar 16, 2011 | 10:24 AM
blazinloud's Avatar
^^^ I think he means the guides or pins
chvy1
May 29, 2008 04:35 PM
shamokin_blazer1977
Feb 24, 2008 04:14 PM
blazermanxx
Jul 21, 2007 04:08 AM
Canadian88
Nov 14, 2006 03:10 PM
jadewolf32
Mar 9, 2006 01:32 PM
