weird ticking from glove box area/hvac only blows hot air
Old Apr 23, 2013 | 08:30 PM
luvmymoneypit's Avatar
luvmymoneypit is on a distinguished road
Originally Posted by LannyL81
I think if you lift the little motor out, you should be able to turn the gears. Might also try to see if the motor will rotate by fingers or reconnect the elecrical connector and hold the actuator in your hand; turn ignition key to ON and then move the HVAC temp control between full hot and full cold to see if everything moves. Be sure to have the temp door in the correct position as the actuator when re-installing it.
I have read that finding the correct actuator can be a problem. There appears to be a slight difference with the aftermarket one so that it will not fit correctly.
umm...how do i know which way is which as far as the temp door and actuator?
Old Apr 23, 2013 | 08:40 PM
ok..so i just went outside and with the top off the old actuator i plugged it in. every thing inside moves but it moves constant non stop in one direction no matter where the heating/cooling **** is turned. i turned the key off, pulled the fuse, waited like 30 sec, reinserted the fuse and turned the key back on...still the same thing is it supposed to turn one way constantly?
Old Apr 23, 2013 | 09:35 PM
Twip's Avatar
i never checked that when i had mine off, but it should turn both ways when you flip the **** from full hot to full cold. i would say that the motor is no good.
Old Apr 24, 2013 | 08:31 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
the motor doesnt know where it is so it cant stop moving. Its always seeing "out of range"
dj00140
Dec 14, 2011 01:58 AM
Familycomesfirst
Apr 8, 2010 11:08 PM
PiTRiFF
Jan 15, 2009 06:59 AM
tschwei
Oct 24, 2008 08:31 AM
jlm33069
May 25, 2006 12:44 AM
