Weird vibration
Old Jun 14, 2013 | 01:20 PM
blown262's Avatar
blown262 is on a distinguished road
Downshifting to 3rd while at ~60 will not redline these. With 3.42 GU6 RPO, you can reach 55 in second gear and have a few MPH till the shift point, IIRC
Old Jun 14, 2013 | 04:27 PM
Originally Posted by Gomli
This forum is awesome, I get zero help on my Focus and Fusion forums lol
Not sure if no one knows how to fix them, or they aren't worth fixing, gotta be one of those options
Old Jun 14, 2013 | 05:37 PM
dman001948's Avatar
dman001948 is an unknown quantity at this point
I had a beater 2001 Ford Focus I use to go back and forth to college with it got great gas mileage. It did do all kind of strange things but it ran..the windows gears were made of plastic so if you held the button down when lower or raising a window you just blew the gears and that was at 100 bucks a pop to fix your self and that was junk yard prices if you could find them...in short supply....the a/c did work it just took awhile to cool things down with those big windshields that let all the sun light in. I would like miss one time going down the road then run okay again....The person I got it off was a women and I don't know who did the work on the car for her for I think they were trying to bump her off...Brake parts missing, cal held on by one Harley type bolt, brake shoes were down to the metal at an angle...car was a trip, no spare tire or jack..good thing I got it on the cheap......traded it for a chevy.....
Old Jun 18, 2013 | 02:26 AM
jimspahr@msn.com's Avatar
Default It could be tires.
It could be a separated tire. It makes a noise like a wheel bearing hum and can cause a vibration. If you had a friend with a good set of tires you could swap out all four for a drive to see if the vibration goes away. If not, then try using your spare and swap out the spare for each of the four tires to see if the vibration goes away. A little work, but worth it to find out free without changing any expensive parts unnecessarily.
Old Jun 18, 2013 | 07:52 AM
spittybays
Guest
Posts: n/a
^ + 1
Check lube diff front and rear.
gERgMan
Sep 6, 2008 07:27 PM
XBlazer01
May 1, 2006 03:30 PM
mattbbb14
Mar 23, 2006 09:46 PM
cthomson
Sep 7, 2005 04:51 PM
blazzinblazer1998
Feb 16, 2005 04:41 AM
