What is this?
Old Oct 5, 2019 | 05:36 PM
Mdz320's Avatar
Mdz320 is on a distinguished road
Default What is this?
You can see it is attached, but loose up top. Is this some kind of test device left behind or not connected somewhere it needs to be?
Old Oct 5, 2019 | 05:45 PM
Someone left part of their fuel pressure tester attached to your fuel rail?
Depending on the fuel pressure tester, some have an adapter that is needed to be used on particular engines. Seems that adapter was left on your engine. Your dust cap is missing now as well.
Old Oct 5, 2019 | 09:54 PM
Old Oct 5, 2019 | 09:58 PM
Mdz320's Avatar
Dust cap?
Old Oct 6, 2019 | 06:20 AM
Originally Posted by Mdz320
Dust cap?
There is a cap that goes onto the fuel pressure test port to keep dust and other debris from getting down into the Schrader valve.
Given that the fuel pressure tester adapter is on there currently, your dust cap is not. Should be easy enough to grab from a junkyard though if yours isn't somewhere in the vehicle.
Old Oct 6, 2019 | 06:22 AM
Mdz320's Avatar
Does it look like a big valve stem cap? I think I found it on the lip at the top of the fire wall.
Old Oct 6, 2019 | 06:27 AM
Yes, same function as a tire valve stem cap, just quite a bit larger. You should be good then to just unscrew the adapter hose and the thread on the cap.
osu89
Oct 19, 2019 12:21 PM
Zindo
Mar 7, 2019 07:44 PM
95BlazerSas
Jan 14, 2019 07:28 PM
konfettix13
Apr 5, 2016 08:15 PM
1baddblazer
Jan 7, 2011 05:43 PM
