What constitutes "high pressure" for HT6 A/C (97 4.3)
I'm thinking 200psi is what I need? (NAPA# TEM 207107)
http://www.napaonline.com/Search/Detail.aspx?R=TEM207107_0064051075
I just replaced my entire A/C system, but Carquest gave me a compressor-mounted low-pressure switch instead of the high pressure switch I asked for.. looks like rockauto has a similar part listing problem for the 97 blazer. My repair shop couldn't get the wiring harness to plug-in, so I told them by phone to jumper the high switch and charge the system. Oops- I thought carquest just sold me a high-side switch for a different brand/year, but it turned out the be a L/P cut-off that looked like my old compressor-mounted switch.
I'd like to leave my system charged and install a retrofit switch on the high-side port, but what is the cut-off pressure supposed to be? I can't find this info on google, but I keep seeing posts referencing working pressures of 235psi on the high-side... So 200psi cut-off would be correct since the switch only stays disengaged at >430psi ????
Also, how often does the H/P cut-off "typically" engage? I'm scared to manually run my A/C in cycles >5 seconds with the high side jumped, especially not knowing if my shop may have slighly over-charged the system. Probably time to buy a set of gauges...
ComputerNerdBD
Feb 28, 2010 11:30 AM
volfan4
Nov 28, 2009 08:04 PM
midnightmekanik
Oct 8, 2009 08:32 PM
cide
Mar 23, 2009 10:57 AM
