What controls the fuel injectors on 2002 Chevy Blazer?
Old Dec 31, 2011 | 06:03 PM
jdmckinney's Avatar
jdmckinney is on a distinguished road
Default What controls the fuel injectors on 2002 Chevy Blazer?
Fuel pump works, new fuel filter, pressure at injectors is good, but will not start. I put starter fluid in intake and motor cranked right up for a couple of seconds then died. Is there a relay for the injectors or could the ECM be bad. Check engine light does not come on. This model engine has 6 injectors so I don't think they all would go bad a once. Thanks
Old Jan 1, 2012 | 12:22 AM
rriddle3's Avatar
Originally Posted by jdmckinney
...pressure at injectors is good...
And you pressure readings are - what?
Old Jan 2, 2012 | 05:04 PM
jdmckinney's Avatar
Just changed out fuel pressure regulator and still same problem, only now the check engine light stays on, starts for a second with starter fluid but that is it
Old Jan 2, 2012 | 05:12 PM
xgiovannix12's Avatar
he asked you a simple question
jumping to conclusions is a way to waste money
get the codes scanned and see what the computer is trying to tell you
Earnhardtfan
May 14, 2014 12:48 PM
dnielsen@kpaccoldstorage.com
Nov 9, 2013 07:58 AM
old88blazer
Sep 22, 2011 10:56 AM
riverjamie
Sep 25, 2007 10:24 AM
mytruck2
Oct 10, 2005 12:45 AM
