What to do about these rotten broken little hoses
Old May 11, 2021 | 06:44 PM
Musgrove's Avatar
Musgrove is on a distinguished road
Exclamation What to do about these rotten broken little hoses
Hi - just bought this 2001 GMC Jimmy and over by the driver side wheel well, there are a set of hoses and couplers and tubes just laying about. They obviously are shot and broke apart over the years, and no one ever chose to replace or repair them.
What are they for, and how should I go about fixing them? They aren't anything challenging or fancy, but for whatever reason, they were neglected. So I'm sure something's not functioning because of it now and I see no reason not to do an easy fix. But I just don't know what they are, if there's anything special I should know about them and their replacements, or if it's nothing to even bother with, which I sort of doubt. Otherwise, GMC wouldn't have gone through the trouble of engineering them in there. Thanks for your help.
Here's a photo:
I can see 3 amputations/problems here.
Old May 11, 2021 | 06:48 PM
If you do a search on here for hvac hose diagram, and find a thread by Christine. She write out what hose sizes and lengths needed to replace. And routing of the hoses.
I've been meaning to do this, but they are not as bad...
Edit:
Here:
https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/under-hood-vacuum-hose-replace-95425/
Old May 11, 2021 | 06:52 PM
Musgrove's Avatar
Awesome! Thank you so much again!
Old May 12, 2021 | 09:58 AM
LannyL81's Avatar
Your Blazer is going to run much better when those hoses are replaced....no more vacuum leak.
Old May 12, 2021 | 11:53 AM
Here's a photo:
Those are the HVAC and 4wd supply vacuum hoses. Check out my thread in these in my signature below.
Old May 12, 2021 | 01:40 PM
puttster's Avatar
Welcome to the forum. Scroll down just five threads to "Vaccum Diagram for 2003 Chevy Blazer."
Old May 12, 2021 | 03:51 PM
Musgrove's Avatar
I certainly will. That's gold. Thank you!!!
Old May 12, 2021 | 03:55 PM
Musgrove's Avatar
Thanks. I may have spotted it if I had known what those hoses were for and were related to vacuum, which was my original question. I've been pointed in the right direction it seems. Thanks!
Old Jun 5, 2021 | 11:30 AM
Lesbest's Avatar
Lesbest is on a distinguished road
Default Vac. hose
That is the vacuum supply for your dash, should have had defrost only. The reserve tank is in the fender, feel around for the nipple, and the long hose comes from the intake manifold. (supply) The plastic hose goes into the pass. compartment. Hope you got it solved.
Zelta
Jan 24, 2021 10:39 AM
cferry7
Jan 8, 2015 01:35 PM
poertsch
May 4, 2012 10:30 AM
fahli
Mar 1, 2011 06:38 AM
cr8390
Nov 7, 2008 08:45 PM
