What happened?
Old Nov 25, 2012 | 09:37 PM
gt77's Avatar
gt77 is on a distinguished road
Default What happened?
So I was driving down the freeway and my temp gauge spiked to hot. I started hearing a ticking sound. Lights dimmed and engine died. Looked at radiator and added coolant and water. Overflow looks sludgy. When I start it up it idles rough. When I rev it it smooths out. What happened and how would I fix it?
Old Nov 25, 2012 | 09:44 PM
gt77's Avatar
Oh, the oil looks good and doesn't smell like gas. The trans fluid looks good and also doesn't smell. There is also a small amount of water coming out of the tailpipe but I don't see any water leaking anywhere else.
Old Nov 25, 2012 | 09:52 PM
richphotos's Avatar
No oil milkshake from water (coolant) getting in it? What kind of coolant do you use?
Old Nov 25, 2012 | 10:36 PM
gt77's Avatar
I just bought it recently so I don't have a particular brand of coolant. I put peak in it because that's what the gas station had
Old Nov 25, 2012 | 11:07 PM
Joshs4x4's Avatar
Joshs4x4 is on a distinguished road
I bet you made chocolate milk.. plan on a new motor.
Old Nov 25, 2012 | 11:08 PM
Joshs4x4's Avatar
Look at the oil.
Old Nov 25, 2012 | 11:22 PM
4x4blazerguy's Avatar
Water out the tailpipe isn't a good sign but not the worst either. My guess would be a blown head gasket or cracked head. So bottom line you may not get water into the oil.
Old Nov 26, 2012 | 03:34 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Depends on how much water is coming out?Is it coming out like water down gasoline or is alot of water.Does a large amount of white or blue smoke come out the exaust?If so you blew a head or intake gasket.
Old Nov 26, 2012 | 10:45 PM
gt77's Avatar
So i took it into the shop and the mechanic replaced the thermostat. The heater worked for a while. Now it's still blowing cold air and the temp gauge is hovering at about 220-230. He said I had only about 30% compression on the 4th and 6th cylinders. Possible break in the head gasket or a bent valve. He doesn't do this kind of work and referee me to someone else. They quoted me a price of between 800-1000. Is this a fair price or should I look elsewhere? Thanks for all the advise so far it's been most helpful.
Old Nov 26, 2012 | 11:15 PM
richphotos's Avatar
Actually water coming out of the tail pipe is normal..
if its a bi-product of coolant or coolant, then its not a good thing,
but just water coming out, is not bad, its happened on all my cars.
