What happened?
Old Jul 1, 2013 | 12:38 PM
What transfer case do you have, (NV233 3 button, or NV236 4 button)?
Old Jul 8, 2013 | 02:27 PM
Zach_99Blazer's Avatar
Zach_99Blazer is on a distinguished road
3 button, and supposedly when I bought the truck it was recently replaced by the previous owner, although i have no proof. It does look a little nicer than other underside components.
I have been messing around with it a little, and i couldn't make the sound happen when i was in 4-wheel drive, knowing what little i do about it. I can get it to happen if i accelerate up a hill and let off the gas when i'm nearing the top, but only if i'm going 40+. Neutral does not make it go away once started, but coming to a full stop makes the sound stop every time.
I almost wish stopping didn't make it go away so I could actually poke around and get a better idea of what was happening.
Old Jul 8, 2013 | 08:06 PM
Here's something to try: Under the battery tray there is an actuator with one vacuum line attached to it. Unplug the line and plug it with a bolt, golf tee, etc. Drive the vehicle in 2WD and see if you can make the noise happen.
Old Jul 9, 2013 | 11:35 AM
1000monkeys's Avatar
1000monkeys is on a distinguished road
I had the exact same problem in my 98. Belt...(or so I thought) would only screech at 35 MPH uphill. Drove me insane for about a week as it would come and go at random times. Checked all the pulleys, new belt, ECT... Finally after pulling out a pound of my now precious hair I stepped on the brake while climbing a hill with the embarrassingly loud screech happening and it stopped.
Right front rattle spring had broken on the disc brake pad and would allow the squeeler to hit the disc at an angle.
Old Jul 10, 2013 | 07:50 PM
Seriously? I would check tonight but Chantel has us battening down hatches here in western PA. I will check when i get home from work. I feel like this sound is too loud to be the squeeler, but we'll see. Ill be back with an answer. Thank you so much
Old Jul 11, 2013 | 11:23 PM
Problem solved! Thank you 1000monkeys.
I took the caliper off today on the fr left and sure enough the one squealer had worked itself off and was caught on the top of the rotor. For whatever reason, when i came off the gas going uphill the squealer started hitting the crossbars between the two sides of the rotor and made the mystery noise. (Just like a baseball card rubbing against the spokes of a bike tire)
I dont know what caused it to happen like it did. But i got excited and drove about 20 miles trying to make it happen and the noise didnt happen once. I have my blazer back
Old Jul 11, 2013 | 11:34 PM
richphotos's Avatar
I am not too sure why I did not think about that on if the sound went away when you hit the brakes. Glad you got it figured out!
Old Jul 12, 2013 | 10:12 AM
You're Welcome! Just glad I could help.
Old Jul 12, 2013 | 04:01 PM
Diaita's Avatar
Good one 1000monkeys!!
Old Jul 13, 2013 | 09:26 AM
Thanks.
Gippy87
May 28, 2009 08:40 PM
fuzzball447
Apr 8, 2007 12:00 AM
TheDesertFox
Jan 2, 2007 06:40 PM
2dr5spdblazer
Sep 29, 2006 11:15 AM
Blazenfast
Aug 20, 2006 10:16 PM
