What happened to my heat?!
Old Jan 27, 2014 | 10:06 AM
offroadsandimports's Avatar
offroadsandimports is on a distinguished road
My floor vents and dash vents don't blow warm air anymore... where is the vacuum actuator?
Old Feb 5, 2014 | 02:23 PM
mwbrown4's Avatar
mwbrown4 is on a distinguished road
Recently changed my heater core and when taking out the dash you have to remember to reconnect all the vacuum lines. I would suspect you forgot one.
Old Feb 16, 2014 | 03:10 PM
Well. I flushed the radiator and put new fluid in. That helped a lot, but I think that the thermostat might need to be replaced because the engine won't heat up at all now.
Old Mar 5, 2014 | 12:38 PM
01TrailBlaze's Avatar
01TrailBlaze is on a distinguished road
Have you checked the intake gaskets?? Sounds more like the thermostat. I have an 01 Blazer TrailBlazer and It had a new radiator put in when the intake gaskets went the first time. They let it go so the transmission was rebuilt too, all by GM. One thing I have learned owning 2 blazers is that the original intakes are plastic and blow easily. SO when GM rebuilt it they put the same gaskets back in that the factory uses and it happened again but quick thinking saved it. Thermostat was tuck open, radiator flushed, new top of the line gaskets to be sure this doesn't happen again soon, and voila, good as new. I recommend thermostat before anything intakes would be if she were overheating.
Gippy87
May 28, 2009 08:40 PM
fuzzball447
Apr 8, 2007 12:00 AM
TheDesertFox
Jan 2, 2007 06:40 PM
2dr5spdblazer
Sep 29, 2006 11:15 AM
Blazenfast
Aug 20, 2006 10:16 PM
