What kind of oil is best on the transfer case 1999 Blazer ZR2
Old Oct 29, 2018 | 10:19 AM
TheSaint's Avatar
TheSaint will become famous soon enough
Default What kind of oil is best on the transfer case 1999 Blazer ZR2
There is a tiny leak, more of a a weat of oil on the seal on the transfer case on my 1999 Blazer ZR2 so i am going to replace the seal where the driveshaft goes in on the transfer case?
So when replacing the seal i will need to replace the oil as well so i wonder what kind of oil is best to use and also how much oil does the transfer case take?
I get 45 percent off on Mobil oils so if Mobil oil is okay to use i will use the Mobil oil
The company where i ordered the seal was not sure of which seal i am supposed to use and told me that there is 2 differnt types of seal i can use so i bought both seals
Can you look at the picture of the seals i have bought and tell me which seal is correct for my 1999 Blazer ZR2?
Updated. I have checked a little and it looks like the largest seal with the boot (MC247) is for the MV236 transfer case which i am sure is the tranfer case in my car because of the 4 switch drive mode program (because of the Auto 4WD switch)
This is the large seal i received today
This is the small seal i received today is for the 3 switch button transfer case which i am pretty sure use Dexron III oil
Old Oct 31, 2018 | 10:04 AM
TheSaint's Avatar
Updated:
1999 Blazer ZR2 use AC Delco Auto-Trac 2 oll if it have the Auto WD button switch (4 switch drive mode).
The amount of oil is 1,9 liter or 2 quarters with Auto-Trac 2 oil on the transfer case according to the owners manual
Old Nov 2, 2018 | 10:25 AM
TheSaint's Avatar
So for my 1999 Blazer ZR2 with the 4 button drive mode panel as shown on the picture below i am pretty sure that the transfer case is a NV236 and the correct fluid for the transfer case is AC Delco Auto-Trac 2
The transfer case takes 2 quarts of fluid from what i have read. The seal is the large "boot" seal MC247
I have not done the job yet but i am pretty sure that this is the correct way to do this job
4 button drive mode panel with Auto 4WD
ID tag on NV236 transfer case
AC Delco Auto Trac II fluid for NV236 transfer case
MC247 "boot" seal for NV236 transfer case
WBFAir
Sep 14, 2014 09:58 PM
chowell
May 6, 2014 09:34 AM
Casole6
Jun 16, 2012 07:21 PM
rbesaw
Aug 14, 2010 09:43 PM
GLBL WMR
Nov 14, 2009 05:54 PM
