What kind of oil viscosity do you use on your 4,3 l V6 Vortec engine?
Old Oct 6, 2016 | 04:17 PM
TheSaint's Avatar
TheSaint will become famous soon enough
Default What kind of oil viscosity do you use on your 4,3 l V6 Vortec engine?
I wonder what kind of oil viscosity you use on the 4,3 l V6 Vortec engine?
According to the owners manual you have to use SAE 5W-30 or if you live in a cold climate to use SAE 10W-30 or SAE 0W-30
I usually use 15W-40 or 10W40 oil viscosity on my cars so i suppose there is nothing wrong in using that on the old Vortec engine in my old 2000 Blazer?
On my Mercedes SL i use synthetic Mobil 1 oil but on my Corvette C2 i have always used mineral oil
I get 50 percent discount on Mobil oil so i usually use Mobil.
I a thinking of using Mobile Super 1000 15W-40 mineral oil on the next oil and oil filter change on the Blazer
Old Oct 6, 2016 | 06:01 PM
richphotos's Avatar
i use what the engine calls for.
Old Oct 6, 2016 | 06:42 PM
newguy's Avatar
use whats called for, otherwise you may stress the oil pump by going heavier
Old Oct 9, 2016 | 02:04 AM
TheSaint's Avatar
I wil use 5w-30 oil
I have a friend that is the importer of Kendall oil so i will use either:
Kendall SAE 5W -30 Dexos-1 Motor Oil Synthetic Blend or Kendall GT.1 High Performance Syntetic Blend SAE5w-30 with Liquid Titanium
If i remember correct the Kendall Dexos is a GM approved oil
Personally i have always liked to use oil that contains as much zink as possible
I was sure that i was supposed pure miner\al oil but my friend said i neded to use syntetic blendor part syntetic oil i we call it up here in northern Europe
Old Oct 10, 2016 | 10:07 AM
LesMyer's Avatar
Originally Posted by TheSaint
I wil use 5w-30 oil
I think that any of the modern oils in 5W30 would be just fine, synthetic or not. Vehicles with roller lifters do not need the high-zinc oils - and high zinc actually poisions catalysts more rapidly (reason they took a lot of zinc out). I really doubt that either of these oils are truly high-zinc, but I would not hesitate to use either of them in my own 2001 Blazer. I would not use either of them in my 350v8 with a flat tappet cam circa 1971. I think better to worry about proper viscosity than to worry about synthetic/non-synthetic oil and zinc content (if you have a vehicle with a roller cam).
Old Oct 10, 2016 | 03:09 PM
TheSaint's Avatar
Oil that contains as much zinc as possible is wat i use on my Corvette C2 and also used on my old Porsche 930
On my modern car i use Mobil Super 3000 synthetic oil and on the Blazer i will use Kendall 5W-30
Old Oct 10, 2016 | 04:03 PM
LesMyer's Avatar
Sounds like good plan.
Old Oct 11, 2016 | 08:15 AM
Tajohns34's Avatar
The 4.3 is pretty sensitive to using the right oil. Just use 5w-30 and you will be fine.
Old Oct 11, 2016 | 03:28 PM
TheSaint's Avatar
Changed the oil and oil filter today so now i am sure that oil viscosity is correct
I used Kendall GT-1 Dexos 1 5W-30 oil and a new Mann oil filter
Attached Thumbnails What kind of oil viscosity do you use on your 4,3 l V6 Vortec engine?-kendall-gt-1-dexos-1-5w-30.jpg
Old Oct 14, 2016 | 07:09 AM
jimspahr@msn.com's Avatar
I rec. 5W/30 in the cold winter months and 10W/30 in the hot summer months. The 'W' stands for Winter. The 5W flows quicker than the 10W and is therefore better for the winter's cold start ups.
Bolbol
18
Jun 10, 2015 02:18 PM
Doctorvette
Nov 5, 2012 11:57 PM
cochran07
Mar 7, 2011 04:36 PM
JeremyG
Nov 14, 2010 01:15 PM
4WDBlaze
Engine & Internal
Oct 20, 2005 12:05 PM
