What is the name of the part the lower fan shroud connects to??
Hi,
On my '02, the lower shroud has 3 tabs on it that connect to a plastic fascia with 3 slots in it. When I was "simply applying pressure" to these slots while trying to re-install the lower shroud, it promptly broke this support "tray" so that it no longer maintains a 90 degree angle. I want to order a replacement but I can't find any diagram that tells me what this part is. The closest I've come in my manual was the support, but that isn't what I'm looking for (the support is over $100, is all metal, and involves a much bigger install than I need. The part I'm looking for is made of plastic and attaches to this support. I can probably find it at my junkyard, but I still need to be able to tell them what I'm looking for.
Some really strong epoxy might fix this, as the break is right in the corner of the tray...but if there's something that works well here I'd appreciate hearing from you on it.
Anyway, thanks in advance!!
spampy
07-02-2012 10:56 AM
mxpxpunkrock1987
07-08-2011 03:27 PM
oshkosh
09-16-2008 04:56 PM
