What is that "ROARING" sound I hear on slow turns?
sounds like something similar to what i had to fix. if you get problems with your ABS light and are able to turn it off by shaking the wheel left to right or pull into a parking spot and the brake drops to the floor, its most likely your hub assembly. its a pain in the butt, and they usually both go at the same time.
As you may recall I asked about a roaring noise when I steer in my 98 Blazer...
I was guided to the wheel bearing and the steering pump - both have been replaced and guess what... the noise is still there
I am now planning on rebuilding the power steering gear box - anybody have any good advice for me on the rebuild???
Thanks for any help, F T P
I doubt that your steering gear box needs to be rebuilt... Roaring noise fro
the engine seems to indicate clutch fan to me... If you had a bad steering box you would know and it typically doesn't make a roaring noise, I'm no mechanic but I've been selling parts an working on cars long enough to rule out your steering box
can you get a sound clip recording ? I'd be interested in hearing it....the reason you are hearing it when you turn at low speeds is because the engine is under high load when turning slow or hard....it doesn't sound like a rattle or knock right, but a roar ? because I had an issue with my flywheel and you could hear it more predominately when turning at low speeds
I will try to get a sound clip, but it is really weird because it will happen for a day or two and then it will go away and may not come back for a week or two. It is describable as a "roar" or "loud "groan".
It is definitely not tires rubbing.
i also get a low groning noise on slow tight turns. but i also have my problem narrowed down to the steering stops it seems to me that my steering stops rub alot on the drivers side with a hard right turn but not on the left side i have replaced all ball joints but is still rubbing alot also when takeing a left turn slowly i hear a scrapeing noise anyone have any ideas im thinking control arm bushings
