what size wheel spacers to get
I have a 2002 2 door 2wd blazer. I just had pepboys put on some 30x9.5 definity dakota m/t's. I love the aggresive look of the tires but it looks weird now. I know some people like wheel spacers and some people say that they are junk. I don't want to open up that argument again lol. I am just curious as to what size i should get. I know that I should get wider in the back than the front because the rear track width is narrower than the front. I havn't been able to find a good answer as to what would look good. Should I get 1.25" in the front and 1.5" in the rear or what. Any suggestions would be appreciated.
unless your ride is lifted i would just add to the rear.
you might run into tires rubbing if they stick out to far in the front.
it just seems like they would with all the backspacing issues that float around here.
ok that sounds good. In that case what size spacers would I need to make the back even with the front? Also anybody have a good brand or one to stay away from? I was also curious where the front would rub? Is it an issue when turning? I thought that the spacers would keep the tires from rubbing on the sway bar at full lock.
Perfect. That's exactly what I was hoping for. Truck looks awesome by the way. Way better than stock. So I will get some 1" and some 1.5". Also some of the spaces on eBay say that they will not work on front of 2wd truck. Anybody know why this is?
I checked out your truck in the build thread. In there it says 2" in back and in here you say 1.5" on back. I was just curious because it looks spot on which ever you have, I just want to order the right ones. Also still no problems with the front being lug centric?
i run spacers from cjbargains on ebay. No problems with them on my 4x4. I have a album of my spacers on here if you would like to check it out it may help ya. Just message cjbargains on ebay to see if they have something that will work for your app.
calee4nyaboy
Nov 20, 2009 11:48 PM
