What is this thing?
Old Nov 30, 2022 | 06:14 PM
Tesroc42's Avatar
Tesroc42 is on a distinguished road
Default What is this thing?
2001 Jimmy
This thing is leaking oil, the top of it spins, and it is right beside the transmission dipstick along the firewall. I assume it's leaking oil because it has fresh oil on it but I could be wrong.
Old Nov 30, 2022 | 09:55 PM
AJBert's Avatar
I believe that is the vent line for the transmission. If not, then someone moved the vent line from the transfer case. Check your tranny fluid level and check to see if that is tranny fluid coming out. My guess without knowing more is your tranny is getting hot or your level is too high.
Old Dec 1, 2022 | 07:53 AM
Tesroc42's Avatar
Thanks. I have an oil leak problem as I can smell oil burning all the time, and this whole area is covered in oil. The only fresh oil that I can see is coming from this little vent thing. Either it is leaking or it is being sprayed onto it. So I will investigate it further today.
Old Dec 2, 2022 | 09:23 AM
martybgood's Avatar
martybgood is an unknown quantity at this point
Looks like the vent for the transfer case. Probably tranny fluid. Does your 4wd work?
Old Dec 15, 2022 | 07:57 AM
GTEn's Avatar
GTEn is on a distinguished road
Only 4wdlow and 2wd
Old Dec 15, 2022 | 08:03 AM
GTEn's Avatar
I also noted that one vaacumtobe from the left side turning to the right side of the engine and going underand its boken, and I dont know where,
Old Dec 15, 2022 | 08:18 AM
GTEn's Avatar
As I told I have a broken vacuumtube I have the end near the engine with full vacuum (plugd) and were is the tubes end?
Old Dec 15, 2022 | 10:54 AM
martybgood's Avatar
Default Vacuum Diagram
Old Feb 8, 2023 | 09:32 PM
2gen2door's Avatar
2gen2door is on a distinguished road
That's the transmission and transfer case vent. If your transmission isn't over filled, id assume the transmission leaks into the transfer case and it over fills and pukes out through that vent hose. I mention this because its a problem I need to fix on my blazer.
Old Feb 9, 2023 | 06:27 AM
Walleye Hunter's Avatar
Walleye Hunter will become famous soon enough
And what is the cure for that?
