What winter and summer tires are you running?
Note the OP has a 2WD Blazer, so the 4WD tires are not what he is asking about.
It's my opinion that with modern tires, changing them for driving in the winter on snowy/slick roads is quite unnecessary. Unless you have a specific reason to get something else (like off roading or high speed capability), just get a normal passenger tire with the highest traction rating (AA) and run them year-round. I had some Goodyears with AA traction rating once on a FWD car and they were great in the Winter (noticeably better). Tread wear is pretty much a non-issue anymore - tires seems to last forever.
If you really want traction issues, try a 2WD short wheel base 2008 Ford Ranger like my wife has (successfully) driven in the Winter for the last 6 years (we have lake effect snow here in South Bend, Indiana). Eight or so bags of softerner salt helps, though! :-)
Check this link out for deciphering tire ratings and let that guide your choices in tires.
What All the Numbers Mean - How Tires Work
I run dedicated winter tires in the winter, all seasons just don't cut it imho. Have run both. That said depends on where you live.
By dedicated snow tires that means that it has the snowflake logo on it here in Canada, I run the winter tire but they are also studded.
You can have the best winter tire in the world, don't help much on black ice. Again depends where you are, how industrious the road cleaning crews are, the greater the population the better kept the roads are.
Off road on some seldom used secondary roads, a winter tire or all season with a set of chains if you need it.
In some jurisdictions, namely Quebec winter tires are now mandatory, many other jurisdictions are pondering it.
From wiki
Snow tires are tires designed for use in colder weather, snow and ice. Snow chains can be a slower-speed, temporary alternative in snowy conditions. Studded tires can greatly reduce skidding and accidents on snow or ice covered roads.[1]
Snow tires have more sipes than summer tires, increasing traction on snow and ice, but reducing grip on dry and wet roads.[2] Tires designed for winter conditions are optimized to drive at temperatures below 7 °C (45 °F).
In much of Scandinavia, Canada, and the US, snow tires may have metal studs to improve grip on packed snow or ice, but such tires are prohibited in certain other jurisdictions because of the damage they cause to the road surface.[3] The metal studs are fabricated by encapsulating a hard pin in a softer material. The pin is often made of tungsten carbide, a very hard high performance ceramic. The softer base is the part that anchors the stud in the rubber of the tire. As the tire wears with use, the softer base wears so that its surface is at about the same level as the rubber, whereas the hard pin wears so that it continues to protrude from the tire. The pin should protrude at least 1 mm for the tire to function properly.[4] Snow tires do not eliminate skidding on ice and snow, but they greatly reduce risks.[5]
Those that want to read the whole article
http://en.wikipedia.org/wiki/Snow_tire
From wiki
I ran BFG Radial TAs on my El Camino year round and they worked really well in snow
the tread is open enough to clean itself even in the greasiest of conditions
I often see"ICE" rated tires but the tread usually looks more like a summer tire IMO and no not work well in snow in my experience
I used Hercules Avalanche on my Civic and was never concerned driving is deep snow
Again a decently open tread that cleared itself
just an update.
It snowed here the past week with an inch or two on the ground.
I drove my Audi 5000 Quattro around the neighborhood in just AWD mode (in this mode any one of the 4 wheels can spin) and I could barely spin a tire with my Michelin X-ice studless snow tires. Turning, braking, and accelerating all had very good traction.
I then backed out the 2WD Blazer and drove on the same streets.
When I first backed out I put it into drive at idle and both rear tires would spin and I would slowly move ahead. That was the first hint of the snow test results. After I get the Blazer moving the ABS quickly come on with even light braking. Turning with just a little power it would slide.
I cannot have wifey driving it like that.
So after Thanksgiving I will get some P235/75R15 DM-V1 Bridgestone Blizzaks and report back to everyone on the results.
BTW - I could really do some great donuts with the Blazer.
Was running toyo ice tires of my Z71 pickup for awhile. Think they were G2's or 3s. Yes ice tires work great on packed snow and ice. Again it depends what your doing with them. One day it rained the night before then froze, everyone was in the ditch except me.
Worked great around the towns, an areas between them. However one weekend hooked up my car carrier, loaded with 4 skidoos and traveled about 50 miles in 6 inches of snow.
Barely made it, cause too much snow for ice-tires, was serious thinking of dropping the trailer and continuing by skidoo.
Ahh hell, still looking for the perfect tire. Have studs on 3 vehicles. Nordic winter Goodyear with studs on the blazer. Also find a narrower tire a 225 instead of a 235 helps alot with these top heavy blazers. imho. (It comes down to the money I guess think it was $120.00 each for the blazer.)
