What ya think?
![Exclamation](https://blazerforum.com/forum/images/icons/icon4.gif)
Check that plug out, thats the #3 Plug, and the rest were like that, think those could have been a culprit in the way my `95 Blazer was running....
Joe
Joe
Kind of hard to tell anything from the picture, but the plug is most likely a symptom of the problem, rather than the cause. Still, changing them would not hurt.
I can't really see anything with that picture. Can you post a better one. I take it that your truck is running better?
As stated, it is kind of difficult to see what you are trying to point out on the plug. It looks like it was running poorly from the color.
Yeah I dunno if you could see from the pics but where the boot goes from the wire they were completely black, I don't believe that is a good sign, I wiped them with a finger and it took a few trys and then u could see silver again underneath all the charing, and then the electrode end was majorly chared and it had a grey spot on the top of the electrode and then all brown by the porcelin base where the spark jumps across.
Still can't believe it but I am pretty positive the plugs that I pulled out are the original plugs put in at the factory and havent been changed out in the trucks 198,000 mile life time
The carbon build up past the threads towards the boot would mean that the plug was not properly seated. This would cause a major loss in compression in that cylinder. I can see how your engine would be better running after changing plugs, or rather torquing the plugs to specs.
butters
02-07-2009 10:59 AM
blazinon22s
09-17-2007 10:12 PM
