What's this???
Old Dec 6, 2014 | 07:33 PM
snuffy's Avatar
snuffy is on a distinguished road
Default What's this???
This vent hose was ran up next to the trans fill/dipstick tube. I was checking it's condition and reached up and other end dropped down. It was just stuck up there. Where is it supposed to go?
Thanks
Attached Thumbnails What's this???-12-6-14trk-blazer011_zps8b3725c1.jpg   What's this???-12-6-14trk-blazer014_zpsb8248fe5.jpg
Old Dec 6, 2014 | 10:11 PM
Vent tube and filter for the 4WD front axle actuator. The black plastic piece stuffed into the vacuum line, (in the first image) is the filter. Year, make, model and transfer case model will tell us where it goes.
Old Dec 7, 2014 | 10:29 AM
snuffy's Avatar
It's a 2001 Chevy Blazer.
Trans was replaced in 2008, wondering if they forgot to plug this back in.
Do you think it goes to the trans or the transfer case?
Thanks
Old Dec 7, 2014 | 01:02 PM
NP236 is a 4 button, Auto 4WD, case. The vent/filter for the front axle actuator is incorporated into the vacuum switch on the firewall,
(sorry, figured you had the 3 button case). The line dangling under your vehicle is the vent for the transfer case. You can see where the fitting attaches in this image: http://www.midwesttrans.com/Np236_TCGM033.jpg
Probably didn't get put back in when they replaced the transmission.
Old Dec 7, 2014 | 01:54 PM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
The front diff vent is on the radiator shroud.
Old Dec 7, 2014 | 02:12 PM
Yup, the front diff vent/filter looks identical to the one for the transfer case.
Old Dec 7, 2014 | 04:08 PM
snuffy's Avatar
Perfect, thank you very much.
Now I know where to put it back in. Then I'll do a transfer case fluid change.
Thanks guys
Old Dec 7, 2014 | 04:39 PM
The NP236 uses a special transfer case fluid, NOT transmission fluid.
Available at GM dealers, ~$9 per quart, and you'll need just under 3 quarts.
Old Dec 7, 2014 | 10:21 PM
snuffy's Avatar
Another thing I did not know, thanks.
Old Apr 5, 2015 | 07:23 PM
Magic man's Avatar
Magic man is on a distinguished road
Default same thing but different year
96 chevy blazer ls 4x4 is mine the same or no
