What's this???
Old Apr 5, 2015 | 08:16 PM
LannyL81's Avatar
Originally Posted by Captain Hook
Vent tube and filter for the 4WD front axle actuator. The black plastic piece stuffed into the vacuum line, (in the first image) is the filter. Year, make, model and transfer case model will tell us where it goes.
Captain....okay a bit confused here....you stated that the line is for the 4wd front axle actuator......but then further down you state the vent/filter for the front diff is incorporated into the vacuum switch on the firewall...????
So is the vent/filter that routes up next to the trans dipstick tube for the trans or the transfer case?...and the one for the front diff is next to the radiator??
Just trying to keep things straight.
Old Apr 6, 2015 | 03:35 PM
Lanny81,
Post #2 presents the question, post #4 clarifies it.
The vent on the transmission dipstick tube is for both the NV233 & NV236 transfer cases. If it has the NV233, the vent for the front axle actuator is teed into the same line. NV236 front axle actuator vent is part of the electro vacuum switch on the firewall.
The line & filter clipped to the driver side of the cooling fan shroud is the vent for the front differential.
Old Apr 6, 2015 | 05:51 PM
Originally Posted by Magic man
96 chevy blazer ls 4x4 is mine the same or no
3 button, NV233 uses DexronVI fluid.
4 button, NV236 uses Auto-tracII.
DON'T mix them up, they are not interchangeable.
Old Apr 12, 2015 | 11:10 PM
Magic man's Avatar
Magic man is on a distinguished road
Okay thanks
